CBM Motorsports LS3, LS7, LSA, LS9 to LS1 Injector Spacer Kit
Old 08-18-2016, 06:40 PM
John at CBM's Avatar
Default CBM Motorsports LS3, LS7, LSA, LS9 to LS1 Injector Spacer Kit
CBM MOTORSPORTS™
LS3, LS7, LSA, LS9 to LS1 Injector Spacer Kit.
This kit will allow you to run GM LS3, LS7, LSA or LS9 injectors in a application where a LS1 injector height would normally be used. These adapters use the factory injector clip and are custom made here in the USA from 6061-T6 aircraft grade aluminum. They are CNC cut on a lathe for an incredibly precise fit and a leak free seal. We also include Vitton oil/gas/solvent resistant o-rings for a long lasting seal.
Available at CBM Motorsports OnLine Store.
Quick Reply: CBM Motorsports LS3, LS7, LSA, LS9 to LS1 Injector Spacer Kit
