need help have a fuel issue
alright start it off have a ls1 in a holden commodore converted
and have an issue engine will only run good at 90 psi of fuel pressure if I set the adjustable fuel pressure reg to 60 psi it barely drives missing carrying on ect just want to know if anyone has come across this and if so what could be the issue
not the factory set up in older model that this engine does not belong using a tomei fuel pressure reg and checked with a test gauge on rail with regulator if I put fuel pressure to the 60 psi factory the car will barley drive
