Max hp racetronix 255 with kb bap and boost!
What's the max horsepower you could get out of sd 60lb injectors , 255lph racetronix Hotwire kit and a kb boost a pump on a turbocharged ls1?
Wow that's not much of an increase over just the racetronix Hotwire and 255 with stock injectors "at least what I've heard" people say the stock system is good for 500 , a 255 should raise the bar some , then you're getting 75-100% more flow with the bap plus bigger injectors . Crazy to think that all that upgrading and your only getting another 100 rwhp
Restricted User
You're limited to the weakest link. Putting 220 lb injectors on a stock pump isn't going to make it flow 1500 HP.
Walbro 255 struggles around 500. BAP might give you 600. As long as injectors flow 600+ then they are irrelevant.
Running a 255 on a turbo LS is an insanely bad idea.
I'm just gonna get ahold of Nasty n8 and see what he recommends for my build. I'm only looking for 550-600 on the ls1 and in all honesty this setup needs to only last about 1.5 months. I was just curious if it would hold up to 8 psi from my Benita 7868, just to have some fun before snow starts sticking ..
I never did a sig? My car is m6 for sure and will stay that way until I ether break the tick performance level 5 tr6060 , or decide to have it be strictly strip only. I know it's next to impossible to bang gears into the 8s , but I'm not looking to be anything more than, a street car that's damn near impossible to touch, and go to the strip and run 9s
Restricted User
Pull that 255 out of there and stop second guessing everything.
Why would I pull a brand new pump and bap out ? If I make 550 then so be it , 650 cool. I was just curious what others have seen this same fuel setup support. I'm going with a complete nasty n8 fuel system and tank in the spring for my tt build so fuel will not be an issue again .
