Multi-Pump Fuel Surge Tank
Old 10-14-2016, 05:08 PM
tedcraig619's Avatar
Default Multi-Pump Fuel Surge Tank
http://www.radiumauto.com/MPFST-Mult...Tank-P271.aspx
Anyone running one of these? I have a 98, so my options for twin pumps are limited. This looks like a win win solution. Wanted to know if anyone has anything like this and how well it works?
Old 10-14-2016, 08:12 PM
Restricted User
JoeNova's Avatar
$600 and doesn't include fuel pumps? Ouch.
http://www.ebay.com/itm/3L-High-Flow...9XaPoS&vxp=mtr
Old 10-16-2016, 04:24 PM
stevieturbo's Avatar
Nuke make similar for slightly cheaper, although only for up to two pumps ( which should cover most applications anyway )
http://shop.nukeperformance.com/fuel...ss-341-gst-450
Yes they are expensive...but a much much neater and more compact solution than an external swirl tank with external pumps, lots of hoses/fittings etc.
Up to you to decide what works out best. You'd save a little going internal due to cheaper pumps, less hose and fittings and it would be easier to install if space is tight.
Old 10-16-2016, 04:29 PM
034 do this external....not the nicest in the world but still fairly neat and compact.
The larger 3L ones are pretty huge.
https://store.034motorsport.com/dual...urge-tank.html
Or there is this for a pair of Bosch pumps....not sure I'd be overly keen on it though
http://www.performancebyie.com/ie-su...let-surge-tank
I see Xenocron make a flange/seals if you wanted to make something like that yourself.
http://www.xenocron.com/fuel-pumps-a...s-c-33_62.html
Quick Reply: Multi-Pump Fuel Surge Tank
