Injectors for mp112
Injectors for mp112
Pulled the injectors off the mp112 mag supercharger for the 5.3 LS motor.. it comes short 42lbs injectors not the full length injectors.. looking into uprgrading the injectors to 60-80s.. I know the newer units come with 60lbs injectors so that's an option.. for the mp112 if I want to run full height injectors what has to be done.. or does someone make an 80 shorty injector.. thanks in advance
Fuel Injector Size = HP
Yes, I sell modified Denso's "short", the size you need is the HP of your engine.
What HP do you want AND Boost Pressure including MAX RPM.
The connector is EV-14 (AC) ?
Lance
Lance
