Using LS3LS7LS9 Injectors w/ truck intake and fuel rail / Which injector spacers
I've come to the point where the 30# 8.1 liter truck injectors I'm using, are almost maxed out. When I put new heads on in the next couple of weeks, I know I'll be at 90-100% idc. It's time to upgrade to some 42-60# injectors. I've found some good deals on LS3, LS7, and LS9 injectors in this range, but they are too damn short. I know there are spacers and adapters out there, but I'm not sure which ones to go with. Can anyone help me out here please. Your help is very much appreciated. Thanks.
Ok lets try another question. What would be the best route to replacing the injectors in my truck (to 42-60# injectors at 4 bar), with budget in mind. I can slap a set of 8.1 marine injectors in and call it good, but it's going to cost me 400-450 bucks. I'm wondering if there is a more cost effective way to achieve the same goal. Thanks.
I'm in the same boat as you are.
I'm thinking LS3 injectors with this adapter: https://fuelinjectorconnection.com/c...ht-adapter-1-2
I'm installing on a 6.2l L92
