Anything i'm missing in this E85 Turbo fuel setup?
Hoping someone can have a quick look at the diagram I drew up of the fuel system I am putting together.
LS1, Precision PT7675 Turbo, 127lbs Injectors / E85.
I already have the surge tank with the twin Walbro 460s, injectors, FPR and Holley fuel rails.
(Surge tank already has fittings, sizes listed in diagram)
I need to purchase the filter, lines, fittings and Y blocks and wanted to see if anyone would change anything / can see something im missing before i start spending money again.
Thanks!
Thanks!
I have a Walbro 255 in the tank at the moment (car is currently cam only LS1) which I was planning on keeping and using it to supply fuel to the surge tank. The only reason I was planning on running the 6AN lines from the pumps is because the surge tank I have has 6AN outlets from the pumps. Will this be an issue?
