Nitrous 6an as fuel return line?
Used a left over 4an nitrous line to drain my fuel when I switched to e85. Got me thinking about using a 6an as fuel return?
It would be less expensive, flexible and require less fittings if I just run a nitrous 6an from my rail mounted regulator as a return to the tank.
Has anyone done this?
You will need to be careful about running a PTFE line with fuel due to electrical charge build up from the fuel passing through the line. You should look into the conductive ptfe. http://www.aerocomfittings.com/electrostatic.html
Racetronix sells the line and fittings and you should be able to make a line for fairly cheap with fittings.
