Corvette Fuel Filter Adapter
I am using a 1999+ Corvette Fuel Filter (the one with built in regulator) on my LS1. I noticed that the output fitting of the filter is a female quick disconnect type. The fuel line for my LS1 is also a female quick disconnect type identical to that found on the fuel filter. Where can I find the adapters necessary to fabricate a fuel line to run from my filter to my fuel rail without getting rid of the quick disconnect from my LS1 fuel line.
Also, I do not know which line is the return on the filter. Can anyone tell me?
~Bob
~Bob
~Bob
~Bob
female on the filter is OUT
large male is inlet
smaller male is return.
you can goto any good autoparts store and look in the help section for quick connect hardline.. they make a piece thats about 3" long with a male quick connect flare on each end... connect one end to the filter, the other to your car.
