Fuel PSI dropping at idle, HELP.
Old 06-27-2005, 04:22 PM
TrakDay's Avatar
Default Fuel PSI dropping at idle, HELP.
Well, we had no issues when the car was on the dyno making 551rwhp and 447rwtrq. But now when the car sits and idles or when I am cruising the fuel psi will drop from 59-60 down to 47psi. And I am not even getting the car into boost or driving it hard, this is just cruising. I am sitll breaking in the clutch. We have replaced the pump twice already with other Walbros and still nothing. We are moving on to check the lines and the regulator.
Does anyone have any other ideas? This is on my 04 Procharged/Cammed GTO with a Walbro pump and 60# injetcors.
Help if you can please!!!
Old 06-27-2005, 06:35 PM
c-PWS-4hp's Avatar
Default Fuel
Remove vacuum from regulator and see iff it goes back to 60#.This is how the system works. Im just not sure what Idle fuel pressure should be but 47 sonds about normal.
Old 06-28-2005, 09:50 AM
WS6FirebirdTA00's Avatar
i would say the regulator
Old 06-28-2005, 10:12 AM
TrakDay's Avatar
We are waiting for the regulator to come in today. Everything else has been checkedtightened and rechecked! Cross your fingers for me that is is in fact the regulator! I want my car back on the street!
Old 06-28-2005, 10:26 AM
keep us posted
Old 06-28-2005, 04:10 PM
TrakDay's Avatar
I hate this!!! I can't just order the regulator for my stupid car. It has to be the entire system!!! There goes another 350!
Old 06-29-2005, 02:29 PM
TrakDay's Avatar
Holy crap we may have a winner! I think the fuel psi issue has been solved!!! We replaced the entire regulator setup on the car and we are steady at 61psi...w00t
Old 06-29-2005, 06:08 PM
sweeeeeeeeeeet
