Gas tank pressurizing problem
Old 07-03-2005, 01:03 PM
GrannySShifting's Avatar
Default Gas tank pressurizing problem
Everytime I pop the gas cap its under PRESSURE
the vent lines are all open on the tank, but Im wondering if one of them needs vacuum or something possible to open a check valve? I thought the vent was ran open to the intake manifold (the evap line stuff) but does it need vacuum pulling on it to open it?
Old 07-04-2005, 01:45 PM
oange ss's Avatar
evap solenoid acts as a relief valve, maybe it's goin out or already bad
Old 07-06-2005, 05:26 PM
Evap solenoid, what solenoid?
its just a tank, strapped to the back of the car all the evap stuff is gone
Old 07-06-2005, 05:40 PM
Taphee6's Avatar
Default pinched line
Check to see if you have a pinched fuel line.
Old 07-06-2005, 05:49 PM
car makes good power air fuel is good.
Old 07-06-2005, 05:59 PM
Taphee6's Avatar
Default Ok
Still doesnt mean you dont have a pinched line.
Old 07-07-2005, 04:23 AM
slowpoke96z28's Avatar
evap solenoid is in the engine compartment
on LS1's it is on the left side of the manifold and has a line that goes to the t/b and the other to the charcoal canister
on LT1's its on the right side of the manifold
the EVAP pressure control valve controls vapor flow to the canister on LT1s. engine vacuum should hold this valve open when the engine is running on LT1s. when the car is off a spring closes this valve until about .7psi has built up in the tank. vapor pressure overcomes the spring and vapors flow into the canister until the pressure spring closes again. LS1's have a line tha goes straight to the canister with no valve. the charcoal canister is(should be) vented on the bottom to atmospheric pressure on LT1s. on LS1s the canister is closed but has a PCM controlled vent valve. either way, if this is blocked and the purge valve doesn't work or is disabled, it may allow pressure to build up.
is this an LT1 car or an LS1 car(sig says LT1 but this is the LS1 section) from there i can explain more.
Old 07-07-2005, 09:21 AM
I said what solenoid because it doesnt have one any more. Car is an LT1 car, charcoal canister is removed, LT1 gas tank (right now only the feed and return fuel lines are hooked up) LS1 motor, the LT1 EVAP line is in the engine compartment, but there is no EVAP noid to hook it too
Old 07-07-2005, 04:05 PM
is the pipe that went to the canister blocked off? how is the tank vented?
Old 07-07-2005, 09:29 PM
ATVracr's Avatar
its all just unplugged vented to free air
