60lbs injectors?
Also, what is the biggest injector, you can run on a stock pcm, properly tuned?
What is the price difference for 60lbs, 72lbs, 84lbs, and 96lbs injectors?
Which ones will work with the stock pcm, properly tuned?
I will be running a single turbo 76gts, curious, what XXlb injectors should I be using? I think the 60lbs will be my weak link, what do you think? The car is getting a complete fuel system to include (fuel lines, regulator, rails, sumped tank, the whole 9 yards), what would you suggest and why?
i decided that the 60#ers may not do it,on pump gas they're ,but if i ever feel the urge to run say C16 and turn the boost up to like 17-18 psi im going to be seeing close to 800rwhp.....I still like Venoms and you sure hear what the company has said about them plus i never said i wasnt going to get another set of Venoms
Originally Posted by anarchy99
Their badass, but I'm just like you... under construction!!! Can't wait to try them out. I thought about going bigger also, but then, that probably wouldn't be big enough in about a week either. Guess I gotta maintain some form of budget for now!!!
