fuel pump install
Old 07-06-2005, 11:41 PM
FormulaFire's Avatar
Default fuel pump install
I have a 255lph Walbro fuel pump. I went to install it the other day, and realized if I wanted to drop my fuel tank I would have to cut my back off of my exhaust. I have heard people do it my cutting above the tank. Can someone PLEASE walk me through the install or give me a site that has detailed instructions to the install. Is it possible to do the install without dropping the tank at all? Is if ok to do? Any cons?
Thanks,
Justin
Old 07-06-2005, 11:50 PM
Agt. Orange's Avatar
i raised my car realy hi in the air and took the bars off for the rear end and dropped the exhaust down and then the tank make sure the tank is empty and you can do it yourself i did its easy
Old 07-07-2005, 01:08 AM
Ferocity02's Avatar
I did mine without dropping the tank. Many say this way isnt as good because you can't clean out the tank.
Do a search. It's called the "trap door" method. I found some pics on here that I used to cut my sheet metal. The install only took a couple hours.
Old 07-07-2005, 03:15 AM
slowpoke96z28's Avatar
i thought LS1s came from the factory with the trap door? WTF?
Old 07-07-2005, 11:21 AM
I've decided on doing the trap door method. I need some 5/16" high pressure fuel injection rubber hose, fuel injection hose clamps, and a small stainless steel clamp to hold the pump inside the rubber boot. Where can I get these items?
Old 07-07-2005, 10:56 PM
DMH Fabrication's Avatar
summit or a local hot rod shop?
Old 07-08-2005, 12:21 AM
Ferocity02's Avatar
Auto Supply
