fuel pump
fuel pump
what is the best aftermarket fuel pump for a 99 z28 with just kooks lts, ypipe, borla, ls6 intake, lid and ported tb? i'm looking to find one for the intank application with little or no modifying. thanks for your alls help.
You don't really need one at your current power level, but if you plan on modding you car (cam, heads, nitrous, or forced induction) it's a good idea. We carry the Racetronix kit that is a complete plug and play solution. You can get some more info about it here:
http://www.harrisspeedworks.com/shop...cat=326&page=1
Thanks,
Matt
Thanks,
Matt
you can buy the stock pump seperately from gm for around 60 dollars...this is the pump and strainer from their crate motor kits.Fuel Pump 25163473 Strainer 25055461...also here is a link where this use this pump in a newer engine swap http://www.4wheeloffroad.com/brandpa...ng/index1.html ...so if you are handy you can save prolly 300+ dollars by using this pump.Unfortuneatly if you need the fuel pressure regulator GM does not sell it seperately.I've read of some guys using the corvette fuel filter(has a builtin regulator)also there are aftermarket regulators you could mount in the tank or in the lines.
another link to pumps below
http://store.getgmparts.com/fuel-pumps.html
fella's i forgot to tell you that my pump is going out. after about 4000rpms it starts starving for fuel, and the pump is winding louder than ever. thanks fellas for the in put.
http://jobberonline.biz/GMFuelPumps.html on this page is the EXACT fuel pump repair kits.Choose youe kit!
VOR52MMPIN GM Fuel Pump Module Repair Kit
This MU (VOR52MMPIN) fits the following MU Numbers (DELCO NUMBERS):
MU151-----MU230 GM--25314333-----25338871
This is a general description of what these MU's fit:
98-99 SUBURBAN-----GMC C2500/3500 (V8)
99-02 CAMARO/FIREBIRD (V8)
This kit Costs 79.95 Plus S&H.
sorry for all these links ...some don't work properly...here is the one to your pump http://jobberonline.biz/GMFuelPumps.html
