NastyPerformance Race tanks- finished
We have finished building some race tanks. They are completed and tested and ready to fly. The tank eliminates the factory fuel pump assemble and use a custom fuel sender. They are completely baffled, sumped, have a 1/2" pipe feed and a 3/8" return. We can add customized bungs to add the fuel pump to the side of the tank for a clean install. I have several in stock so let me know if you need one.
Sumped race tank w fuel sender $529.99
http://www.nastyperformance.com/images/Img37.png
Thanks Nate
Thanks Nate
Nates stuff is top notch, I have his intake, gastank, and valvecovers and everything is perfect.
BTW Nate you need to see what I did to your gas tank, My wheelie bars wouldnt clear it, so I had to do a little narrowing action, chopped 7 inches off both sides, now I have the only MINI-Nasty gastank in the world Hold about 5 gallons now
89lx-ls1 We do have one just like it to fit the Mustangs give me a call and we can get you one. Instock
Dez yours is ready to fly
BTL FED you need to send me some pictures of your car and that tank. Is that thing running yet?
Nate
Nate
...with cheese.
I've got one of Nate's tanks, the quality is superb. I need to talk to you about a custom sender though Nate. My gas gauge doesn't read. How is this custom sending unit different?
SSU'S Vice Mod
Fuel capacity in one of these tanks vs. a stocker? What about weight vs. a stock steel or plastic (dry)? Awful lot of coin to drop on one of those tanks, but I know what it's like to go through a fuel pump replacement when it dies on you in the middle of a parking lot and it sucks. Plus, no worry about getting down slightly below 1/2 or 1/4 tank, just that if it's a peanut size, it'll make me change my mind.
SSU'S Vice Mod
Originally Posted by Armageddon
it holds about 12 gallons I think, I get atleast 40 miles to the tank
Andy, how much of the time do you spend WOT though?
The sender is a complete different unit. I am not sure how we could incorperate it into the old tank without rewelding the top of your tank?
That is some great gas mileage.
Nate
Nate
Nifty, thanks. Forgive my ignorance, I've never built a fuel system like this before, but is this tank more oriented toward a drag racing vehicle or is it also appropriate for other applications? Simply put: what are the restrictions and drawbacks? The advantages are obvious.
...with cheese.
I've got the stock sending unit and all that good junk in mine. I just left the whole assembly in there so I could use the sender. Is there something different that I don't know? Do I need a different sending unit?
Drake-It is good fro any racing it just adds the sump to pull fuel from the bottom with a larger inline pump. No disadvantage that I can see.
Armageddon-Your tank is fine the way it is. We just changed the sender to ease building and to eliminate the big bucket from the tank.
Dez- great to here it all went well your other pumps and stuff is on the way.
caindo- you are at the limit of your stock tank in the GTO already? What setup are you needing it for? Just need a sump? We have not been asked for one yet but I will look into it. If you are serious call me we will work something out.
Nate
Nate
