Braided AN from PUMP TO FUEL RAIL??
Old 08-02-2005, 09:44 PM
25thredrs's Avatar
Default Braided AN from PUMP TO FUEL RAIL??
I need to know how and what I need to run an 8-AN braided steel line from the top of the tank (quick connect fittings) to the fuel rail quick connect and to a 6-AN return line....
Has anyone run Braided Steel line from the tank to the rail??? any help would be greatly appreciated.
Thanks,
25thredrs
Old 08-02-2005, 10:03 PM
V8_DSM_V8again's Avatar
Thanks,
25thredrs
https://ls1tech.com/forums/showthrea...=AN+fuel+lines
You can Just use the nipple style QRs and clamp them on using a better looking hose clamp or the AN knock off cover over a FI clamp...
Or get the "puire choice" adapter fittings.
http://gmhightechperformance.com/tec..._snow_06_s.jpg
I would actually do what these guys did to a LT1...
http://www.gmhightechperformance.com/tech/0409htp_snow/
Depending on your power goals you may want to go to a dual feed.
I know they are different but you can divorce the rails giving each its own end of a regulator, V-block (or twin pumps)....
http://www.performanceplumbing.com/FuelLineKits.html
Old 08-03-2005, 06:28 AM
25thredrs's Avatar
Thank you that is very helpfull....So can you get those fuel rail fittings in 8-AN. and can I use the same ones at the tank that I did at the fuel rail...
Also I am running an external regulator and I think I have to remove the stock regulator..Am I correct and where is it located to remove it.
Thanks,
25thredrs
Old 08-08-2005, 09:20 AM
Wet 1's Avatar
That GMhightech is a good read, thanks for posting that V8_DSM_V8again.
