Fuel Pump????
Fuel Pump????
Hey guys I just got my car out the shop yesterday. 24k Tranny cooler, transgo shift kit, vig 3200 converter. Here is the problem at WOT right AFTER it hits second gear the car stops going fast and sounds like its not geting any gas. But if I take my foot off the gas for just a second then hurry up and get back on it then it does not do that. I was wondering if its a fuel pump problem. no codes
fueling problems
i'm not positive but some of the newer cars & trucks have a fuel stop after 6300 rpm it shut the fuel pump down it's some kind of stuipid saftey thing that gm put in ...i'm having the same problem .. they make a fuel booster that puts more volts to the pump so it pumps faster to give you more fuel .. don't know if they high volume pump for the newer vechicles i have a 2004 silverado with 44lb injectors pro charger heads , cam , headers . i'm looking for a salution too good luck !!!
