36 lb injectors????
You don’t need the injectors for the nitrous, as you’re spraying a wet shot. But it wouldn’t be a bad idea to see where you duty cycle is on your stock ones, since you have a cam and bolt ons.
I would highly recommend an upgraded fuel pump if you are going to spray a 150 shot. My suggestion would be for the Racetronix set up. It’s a plug and play system, pretty easy install, and it’ll support the power you’re going to be making. For more info:
http://www.harrisspeedworks.com/shop/home.php?cat=330
Let us know if you have any other questions.
Thanks,
Matt
Thanks,
Matt
Originally Posted by 00ls1
i did the formula up top and got the # 37.??? would 36 pound injectors be alright for my set-up, and a 150 wet shot>?
doug
doug
