tried techron......nothing......
alright, i posted a while back because my car is missing, stumbling and surging pretty badly, and everyone suggested running techron through it because the dealership said that the fuel injectors were clogged and not putting out the pressure that they should. so after running the techron through it, absolutly nothing has changed, it may have even gotten worse. so the dealership said that they would run a cleaner through it, i guess they hook it up to the schrader valve on the fuel rail, and let it run through the entire top end of the motor, and from what i was told by a few people it does an awesome job of cleaning the motor up...intake, valves, spark plugs, fuel rails, fuel injectors, piston heads... have you guys heard of this procedure and know if it's any good? or should i just get new injectors? thanks.
