Fuel cell, pump, etc help
Hey guys, I am ditching the stock tank and want to go to a 5 gallon fuel cell. I want a fuel system that is capable of handling a stroker motor on a healthy nitrous shot. My question is...what is the best route to take as far as which cell, pump, etc. thanks.
I'm running a summit 16 gallon foam filled sumped plastic tank with a "Y " fitting to a 60 micron filter then to a 72 GPH Carter 6 psi rotary pump to a Airtex E2315 pump to 10 micron filter to an Aeromotive regulator. 8AN lines to the Carter, 6AN forward. Everything is mounted in the trunk so very short return line (6AN).
Works for me
Works for me
