whats the best on line fuel pump
the walbro 255 is only like $110 (ebay) http://cgi.ebay.com/ebaymotors/Walbr...spagenameZWDVW
and its even a sponsor (full throttle) so this post shouldnt be deleted
good luck
mark
good luck
mark
Originally Posted by Matt@HSW
When you say on line do you mean in line? If so, IMO you'd be better doing an intake one.
Matt
Matt
I will be ~510rwhp with the NX Kit hit. I hope it will be enough.
Anyone know of anyone who lost a motor because if an inline pump gone bad?
It's not the best way of doing things. Look at it this way, how can it supply more volume when there is a restriction in front of it (the stock in tank pump)? The in line pump is not going to be able to pump any more then the in tank pump. The in tank Racetronix pump kits are pretty easy to install and will work perfectly for your application. I know they are a bit more, but you already have a good amount tied up in your car, why risk it now?
Matt
Matt
Just remember this . A pumps ability to pump volume is dependant on pressure. Lower presure = higher volume. When you add an inline pump and put a gauge between them you will find that there is far less pressure between the pumps that after the inline pump so the "system ability" goes up a good amount add a hotwire kit to the stock pump and it will be even better. A good intank pump is better but not much. All intank pumps currently available are Walbro either GSS340, GSS341, or F2000169 which are all the same pump with slightly different inlet and outlets. The jet pump in the take needs to be run by taking a small amount of the pumps output and sending to that to suck out the last few gallon of gas. some do this by installing a nipple in the top of the pump and some by putting a "T" in the outlet of the pump to connect the small line to.
Mike
Mike
LS1TECH Sponsor
An in-line pump for the F99+ modules is not the best solution as it can cause problems with the fuel system's functionality. Although our in-tank system is a bit more work to install than an in-line pump it would be well worth the time investment.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Dumb Ass Vette Moderator
Keith
Depends on the application (NA/FI/N2O). We've taken heads/cam cars with decent size shots to a little past 650 RWHP. That was using a single pump Racetronix kit with a fuel rail mounted fuel pressure regulator and a return line.
Matt
Matt
Originally Posted by Wet 1
700ish? Not from what I've seen...
LS1TECH Sponsor
Originally Posted by ls1290
What about using an inline pump with your setup? I have heard your pump is good to about 700ish rwhp.
Keith
Keith
If you need more fuel than our single in-tank system can provide it is time to consider losing the bucket and going with another solution such as our DP in-tank system.
__________________
>WEB SITE<
>WEB SITE<
We don't recommend adding an in-line pump to the bucket system.
Keith
LS1TECH Sponsor
Do you have a C5 setup?
Keith
Keith
http://www.racetronix.com/RX-C5-FPK-2.html
This system now includes the pump fully assembled in a new bucket with Racetronix upgraded in-tank wiring, flex-tube and both filters.
It is available through sponsoring dealers on this forum.
__________________
>WEB SITE<
>WEB SITE<
Yes we do here:
Keith
LS1TECH Sponsor
How much will this system support with and without a BAP?
Keith
Keith
Typical numbers based on adequate fuel volume assuming stable regulation (BSFC dependant):
600RWHP NA w/o booster (13.5V)
700RWHP NA w/booster (17V)
550RWHP FI w/o booster (13.5V)
650RWHP FI w/booster (17V)
Some customers have exceeded these numbers and some have fallen shy depending on their application. A 97/98 FMFPR system is highly recommended for all applications.
__________________
>WEB SITE<
>WEB SITE<
