Ford Motorsports Fuel Injectors
I was told by the tuner guy here in town that he recommended these injectors cause he know exactly what they flow or some crap like that. Are some injectors better then others? I was looking at getting the racetronic fuel kit along with the dlphi / lucas 42# that are verifyied by racetronics. Am Im missing something or was the tuner guy on crack? cause it says the exact flow rates and everyhting
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Static Flow Rate: 48.83 lb/hr @ 58.0PSI (300kPa) or 370gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
I always suggest you purchase whatever injectors the tuner that you are going to use recommends, as the end result will be that you may get a better tune. The SVO injectors are used by most tuners, and are a very popular choice. We use them in most of our installations. Bob
I have a set, never installed. SVO 42# injectors. Debating on going to 60's before I install them, as once installed, used injectors lose thier value quick.
make me a reasonable offer, and they're yours. Ryan212@aol.com
Having correct injector comp batt voltage, and injector flow rates for different pressures make it easier to tune. I like the ford injectors, for all of the ford tuning i do, as i can simply load most of the lighting values into the tune, and be very close.
Ryan
Ryan
