Question on my fuel system setup.
ok guys, what will i need to upgrade..
car - 2002 Z06 corvette
upgrades - 408 iron block stroker from HPE
Big E cam (244/248 612/615 on a 115 LSA)
all bolt ons
and a good shot of nitrous (starting with a 150 but will probly shoot a 200)
im guessing i will need to upgrade my fuel pump, the nitrous will be a wet kit so fuel will be suplied by the jet not the injectors,
will i need bigger injectors??? what injectors come on a LS6??
help me out guys
all bolt ons
help me out guys
I would go with 42lb injectors and I am not sure if Vets have the same setup but I would go with the Racetronix setup and a BAP. This will use all the stock lines and rails. Depending on how much power you are going to push you may have to upgrade Lines and Rails. Since I just went through all of this if I could do it again I would start off a little easier then going all out. Once the new motor is in see how your AFR reacts to the power.
Kane
Kane
