My fuel system gonna be enough?
I'm putting in my new motor next week and will be getting ready to spray it in a few weeks. Will be spraying 150-200 on it and need some input on fuel system. Will have racetronics pump kit, racetronics 37 injectors (42.5 at 58), and FAST rails. The motor should make 475-490 rwhp NA, and around 675ish on the 200. At what point do you have to run a BAP to ensure fuel delivery. How much HP can the stock lines handle? Thanks.
John
John
Nate,
What is the better way to do it. The 8an feed and stock line for the return? With the lines done, how much pump is needed to feed it? Will twin 255 intanks be needed or will the single/BAP setup be good to 700rwhp? Thanks very much for your time.
John
John
