Stock fuel pressure? - LS1TECH
Thread Tools Search this Thread
Old 09-23-2005, 05:29 PM   #1
Runn's Avatar
Default Stock fuel pressure?
Whats the stock fuel pressure on a 98?
Runn is offline   Reply With Quote
Old 09-23-2005, 06:10 PM   #2
Matt@HSW's Avatar
Usually around 57 - 58 ish psi.
matt
Matt@HSW is offline   Reply With Quote
Old 09-24-2005, 01:05 PM   #3
Runn's Avatar
How big injectors is possible to run with stock pump?
Old 09-24-2005, 03:14 PM   #4
hp is the limiting factor on a stock pump not injector size
oange ss is offline   Reply With Quote
Old 09-26-2005, 05:13 AM   #5
Runn's Avatar
But there have to be a limit to the injector size right? When the pump can run them at 100% anymore....
Old 09-26-2005, 01:05 PM   #6
not really, pump has nothing to do with injector size, the pump is there to meet the fuel consumption of the engine , the VCM controls injector duty cycle depending on fueling needs and of course fueling needs can surpass the safe operating limit for injector size
Old 09-27-2005, 01:53 PM   #7
hawaiiboysz's Avatar
So there is no need to upgrade the pump then? Just injectors So when would you need a pump?
hawaiiboysz is offline   Reply With Quote
Old 09-27-2005, 02:36 PM   #8
Quote:
an upgraded pump is always a good idea, but you really wont need one till around 450 rwhp, the 01-02 injectors are good for about the same power range, the 98-00 cars will need to upgrade injectors around 400-420 rwhp
Old 10-24-2005, 06:44 PM   #9
Quote:
matt
44psi too low or is that "within a safe range" ?
slmdLS1 is offline   Reply With Quote
Old 10-24-2005, 07:24 PM   #10
too low
Old 10-25-2005, 12:54 PM   #11
Matt@HSW's Avatar
Too low.
Matt
Old 10-29-2005, 07:25 PM   #12
got it up to 58psi constant.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
