Any pics of dual intank walbro's on 99+ cars?
I searched for some pics of the dual intank setup and only found a couple of hellraiser's setup. I would like to see some more because i want to know what i have to cut and drill out before i mess it up I just got my Nasty dual intank fuel setup and will be installing it this weekend if all goes well. I am using the home depot 3/8" inlet to 3X1/4" outlet for the intank feed from the pumps to an -8 bulkhead 90 degree fitting which will come out of the sender. Anyone have some advice for doing the install or is it pretty straight forward? Thanks!
Greg
Greg
If you got the nasty setup then I don't know what else you would have to drill and cut. The only cutting and drilling I had to do was on the fuel pump housing thing. After that everything else was easy. Are you running a FPR up by the rails? I put one right on the stock feed line as that was my new return. I pretty much did what MightyMouse did on his setup.
