Do I need new injectors?
I am planning on installing a cam in the near future and I was wondering if I needed to bump up my injector size for this. I think I am having a problem with one or two of them now, and I dont want to replace the bad ones with a stock size and have to change them out when I put in a cam. The cam I a looking at is fairly large, around a .600 lift, don't know the duration or lsa, guy that owns the shop says that it's all a big secret. He says that with the cam and the exhaust that I have I should see between 390 and 400 rwhp. Is that out of line? Thank's for the help ahead of time.
30# injectors would be a good choice,you shouldnt max out the stock injectors @ 400 rwhp but you would be getting close.If you think you have a problem with your injectors know I would swap them out
Brent
Brent
Brent
Brent
brent tuned my car and I am bolt on's with a cam. stock injectors and not having a problem. when I decide to go turbo I will jump to 60#'s. gives me more breathing room when I want to turn up the wick.
