Walbro fuel pump?
Walbro fuel pump?
Hey guys, wanting to replace my stock fuel pump. I'm running 400RWHP and I'm still running on my stock fuel pump and was thinking of replacing it with a 255lph Walbro, do you think this would be sufficient? Do the Walbro's just bolt right in to the stock location? Do you need to run any special fuel lines or anything more than stock has? On the sight it said that you need to run a fuel pressure regulator. Sorry for the noob questions, I've just never personally replaced a fuel pump before so I'm not for sure? I'm just looking at the Walbro's because they are all $99 right now w/ free shipping and I've heard they're good for medium hp applications.
I just installed the racetronix kit. WELL worth the extra $150 to do it right. Everything is there including the harness...why put in a higher flow pump and not supply it the proper voltage??
