Racetronix hotwire kit
Old 01-18-2006, 09:15 AM
pasbonsimon's Avatar
Default Racetronix hotwire kit
the + wire is clearly labeled "Alternator" - is it okay to connect it to the + battery instead of the alternator?
Old 01-18-2006, 06:29 PM
JRracing's Avatar
Yes. But the altinator would look cleaner. It would be connected out of sight. Thats the way I'm doing it.
Old 01-18-2006, 06:39 PM
618HAWK's Avatar
Have you thought of using the AUX post? Keeps the harness on the left side of the car away from the hot items, easy clean routing.
Old 01-18-2006, 07:17 PM
1redta's Avatar
Default re
I thought the reason you would use the hook up on the alt. is because it will provide the highest voltage to the pump
Old 01-19-2006, 10:50 AM
618HAWK's Avatar
If I recall the aux into the back of the Alt. but I could be wrong.
Old 01-19-2006, 11:03 AM
GTOTitoLS1's Avatar
Default fuel delivery
gone.
Old 01-19-2006, 11:07 AM
618HAWK's Avatar
Yes but some do not wish to hack up there full bucket.. and would spend a few more $$ to have a plug and play.
Old 01-22-2006, 04:17 PM
shouldn't the voltage at the battery be around 14 volts when it is running anyway?
Old 01-23-2006, 12:05 AM
BudH's Avatar
Where did you buy the harness/hotwire kit?
Old 01-23-2006, 02:20 AM
LS1TECH Sponsor
Racetronix's Avatar
Thunder Racing stocks these harnesses.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 01-23-2006, 09:06 AM
HellRaiser's Avatar
Originally Posted by GTOTitoLS1
this pump goes in the tank replacing the stock one, delivers 255 liters per hour, good enough for any turbo up to 17psi and nos
I think this is bad info. A Ls1 @17psi would be making 0ver 700rwhp and you wann throw NOS on top of it. All this power with only one pump? Sounds like a setup waiting to go
Old 01-23-2006, 09:31 AM
I purchased mine from http://www.harrisspeedworks.com/ with 42# injectors - the best pricing on injectors and very fast shipping
