600hp on 42lb injectors?
11 & 7 Second Clubs
My motor makes over 400 rwhp N/A, and on a 200 dry shot my 42# injectors only work at ~70% duty, so the answer is yes.
Originally Posted by KraZy
Is it possible to get 600hp on SVO 42lb injectors?
Stock injectors will support over 500hp,
but this is an issue of working with boost pressure, so injector output drops comparing to the same fuel pressure NA.
Keep in mind the 42 lbs are rated at 43.5psi fuel pressure,
so if you run 60psi fuel pressure that brings it up to 49 lbs with NA operation.
If you run 10 psi of boost that takes you back down to 45 lb/hr.
