Gas Gauge Not working
Old 01-27-2006, 02:00 PM
01 Red WS6's Avatar
Default Gas Gauge Not working
my gas gauge isn't working. It threw a code for the fuel sender unit. I can't remember the code off the top of my head but I'll get it later. What should I look into replacing to get it working again? I know on my truck I had to replace the whole sender unit but I'm not sure on this car. Any help would be great.
Also while I'm back there should I go ahead and upgrade my fuel pump? I know I don't need it yet but I figure it would be easier to do it now than later.
Old 01-27-2006, 05:10 PM
Mark98SS's Avatar
If you can afford a new pump do it while you are there. The Racetronix pump & plug n play wire harness is easy to install.
Old 01-31-2006, 03:20 AM
raul602's Avatar
my gas gauge is not working as well. anyone got a part number?
Old 01-31-2006, 11:28 AM
01 Red WS6's Avatar
From looking around I think I have to replace the whole sender unit. List from GM is $650 (I won't be paying list)
Old 02-01-2006, 12:34 AM
LS1TECH Sponsor
Racetronix's Avatar
The ceramic level sender itself can be bought as a service part from many GM parts dealers. Check to make sure it is the sender and not a bad connection first by going through the GM factory manual's diagnostic procedure.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 02-01-2006, 12:19 PM
01 Red WS6's Avatar
Thanks I'll check it out
Old 02-03-2006, 08:58 AM
01 Red WS6's Avatar
Can you help me out with the procedures? Or tell me where to look? I have a manual but I don't know where to look since it's seperated by codes.
here is what the gauge does:
The gauge will read correctly till I get to 1/4 then it just won't work or it will not read correctly. But once I fill up the car it will read fine again. I had a code thrown and it had something to do with the sender unit but I'm not sure what the code number was or what exactly it said I just remember it was for the sender unit.
