Racetronix/Hotwire Fuel Pressure fluctuates with nitrous
Old 02-11-2006, 02:42 PM
BadAssFast's Avatar
Default Racetronix/Hotwire Fuel Pressure fluctuates with nitrous
I have a properly and well installed new Racetronix fuel pump and the hot wire kit. Everything installed to exact spec. When I drive the car I have excellent fuel pressure 63-4 psi. My elctronics Autometer sender is at the test port on the fuel rail...when I nail my nitrous my fuel pressure fluctuates as much as 20 psi. How can I test the fuel pump to eliminate it as the problem?
Old 02-19-2006, 12:59 PM
WS6FirebirdTA00's Avatar
what size injectors do you have? and what kinda power are you making?
Old 02-19-2006, 01:31 PM
BadAssFast's Avatar
This info is very specific in the link in my sig (http://sig.macon-moore-performance.com) but generally the numbers 430 RWHP NA at 585 RWHP w/ 150 wet. Keep in mind 4L60E and SS3600 Stall with 4.11 rear. Racetronix (Lucas) 42 lb injectors.
Old 02-19-2006, 01:47 PM
reason i asked is i was wondering if you were maxing out the injectors and it was causing this drop, either that or maxing out the pump? im not sure the limits onthe pump though
Old 02-20-2006, 12:19 AM
LS1TECH Sponsor
Racetronix's Avatar
Without a FM FPR installed pressure fluctuations in the range of 52-62PSI are not uncommon. This is a shortcoming of the factory system.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 02-20-2006, 07:30 AM
BadAssFast's Avatar
FM FPR I don't want to assume anything please decipher this acronym.
Old 02-20-2006, 07:32 AM
Matt@HSW's Avatar
I'll take a stab at it: Front Mounted Fuel Pressure Regulator.
Matt
Old 02-20-2006, 10:29 AM
BadAssFast's Avatar
Matt
I'll bet you are right there Matt...it has been suggested to me by a couple of folks here (possibly you included) that a replumbed system including a fuel pressure regulator mounted up front and return would be a solution. Again thank you Matt. I think I have a solution that I will try. I will get back with the results.
- Macon
Quick Reply: Racetronix/Hotwire Fuel Pressure fluctuates with nitrous
