Aeromotiver fuel rail question. Where to mount???
Old 02-18-2006, 12:11 PM
00turboT/A's Avatar
Default Aeromotiver fuel rail question. Where to mount???
I have a set of aeromotive fuel rails that I bought and no matter how you turn them the brackets on the rails will not mount into the factory holes. I tried posting this in the fuel section and no response so I though I would try here because there have to be people running them. I have only found a pic of one set and there are mounted on the little brackets on either side of the intake and not in the factory holes. That makes them able to move in my opinon. Gas bursting onto a hot turbo not a good day. Any pictures or advice would help.Thanks
Old 02-18-2006, 08:37 PM
camrsz's Avatar
Do they not line up or are they just to high? I had to flip my brackets upside down from the way they were out of the box.
Old 02-19-2006, 09:57 AM
smokinHawk's Avatar
i keep everything loose untill i have it all together then tighten up the screws. im not sure of the tolances maybe you got a bad one?
Old 02-19-2006, 11:49 AM
stevieturbo's Avatar
Ive Aermotive rails on mine. I dont remember having any difficulties with fitting them...
Well, aside from using the Siemens 57lb injectors and the wiring plug sits slightly higher, which meant it fouled my rails. Little work with the grinder and it was sorted.
Rails
http://gallery112848.fotopic.net/p8886914.html
Old 02-19-2006, 10:34 PM
DeltaT's Avatar
How close are the holes?
Jim
Old 02-20-2006, 03:22 AM
00turboT/A's Avatar
There are about a quarter inch off on both sides. The holes just will not line up on them. Well I decided to do the smart thing and buy some FAST rails so there on there way now. Anyone want an extra set of aeromotive fuel rails for $100.00???
Old 02-20-2006, 11:49 AM
Nasty N8's Avatar
FAST? Why not some Nasty rails we have been selling fuel rails for 4 1/2 years for the LS1 and never had a fitment issue. I also have a complete line kit to hook directly to your factory feed line.
Nate
Old 02-20-2006, 11:56 AM
Deranged Rat Fink
badjuju342's Avatar
My Aeromotive rails bolted right on my LS6 intake , no prob.
Old 02-20-2006, 12:11 PM
Post a pic, perhaps someone sent you the wrong rails ??
Although they are really just a bit of extruded tubing with a bracket bolted onto the side.
Hard to imagine how badly wrong they could be, if indeed they are the correct rails
Old 02-20-2006, 12:26 PM
thunderdan74's Avatar
Maybe those rails are for a LS2 intake. The fuel rail mounting is a little different on the LS2.
