Injectors and Fuel pump Questoin !!!!!
I have just purchased an ATI Procharger kit and on the side I also purchased a set of 42# injectors and a Walbro in tank fuel pump. I need to have both of the fuel components installed so that I can devote a whole day to installing the Procharger. Can I install The Walbro 255 fuel pump and 42# injectors and drive it fine without any problems or do I need to do it all at once. Please help, all advice is greatly appreciated.
You can do injectors and pump at once but you will need to have some way to reset your IFR table, ie LS1Edit,HPtuners.
That is a common problem for most with the install, once injectors are installed will run WAY to rich, and you can not drive it. Next best thing to do is do all your mods and installs and drive it easy to where ever you are going to have it tuned and swap out your injectors. Just keep your foot out of it. Or tow it.
