quick plaese!! what is the stock ls1 fuel pressure reg supoosed to be set between??
Old 02-25-2006, 11:19 PM
Mr_president's Avatar
Default quick plaese!! what is the stock ls1 fuel pressure reg supoosed to be set between??
tittle says it all!!!
Old 02-26-2006, 09:14 AM
LS1Tech Sponsor
Slowhawk's Avatar
58-60psi
Old 02-28-2006, 12:35 AM
i have it 59 smelllllllsss sooo rich
Old 02-28-2006, 04:59 AM
RedWS6 00's Avatar
Perhaps Cats on the way out?
Also mine smelt rich last weekend, I found my Injecor Pulse table was out, I thought I had it right after I changed injectors, the values I entered were actually too low, which meant the PCM thought it was injecting a smaller amount of fuel, this then meant it would try to play with fuel trims and it couldn't adjust enough to make 14.7 AFR.
Have you played with the injector table?
Old 03-01-2006, 12:51 PM
not yet its going to change when the turbo goes on in the next few weeks after the head cam change!
