In-tank pump for 70 F body tank?
If you could incorperate a Walbro in your tank that would work. There is not going to be anything simple as your car used a carb pull pump. Easy would be to add a sump and use an inline pump and complete the system.
Nate
Nate
Thanks for the reply. I have the donor fuel pump, but my tank is not deep enough to use it. I guess I'll have to check some catalogues to see if there is a in-tank pump I can use. I'll probably end up with a sumped tank and in-line pump, I was just trying to do this a little low key visualy, fuel lines and such are gonna be really visible with a sump.
