how many HP is a dual walbro good for?
Hey Nate I've been told running a dual intank 340 Walbro set up (properly wired with the racetronix wiring kit) with stock feed and return line, the factory regulator removed, a front mount regulator and good fuel rails can produce over 1000RWHP on a Turbo car. Is this not correct? What about SC set ups?
I also heard, if this is true, Ligenfelter uses stock feed and return lines on most of their high HP cars...what are they doing we're not?? Looks like me and Mike (IconAuto) will be contacting you soon for some things needed for my next project...
Maybe 1000fwhp puts you about 850-900rwhp with the 2 Walbro pumps. I could see it happening but not the best way to go about it. The stock setup does not have a return so you would have to add a feed use the stock as the return You are replacing most of the system anyway why not add a good sumped tank and a better extrenal pump setup and be done and not worry about the problems with the dual intanks failing, leaking, fitting properly...
Nate
Nate
