Car Running Rough!!
Car Running Rough!!
OK SO MY CAR IS RUNNING ROUGH AND I SMELL A LOT OF GAS!!!!
THESE ARE THE CODES!!
P0131 (M) 1/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
SOME1 PLEASE HELP ME I DUNNO WHAT TO DO!!!
i dont have 1 i have long tubes and when i got my car tuned those codes were deleted, now i only have the 2 rear ones and i juss replace them like a week ago when the ses light came on
kept the REAR ones??
That seems Bass Akwards......
B1S1 and B2S1???
I hope you mean you kept the fronts, and deleted the rear.....
I know FunkyTownFbody above said to change out your Front Pass. Side O2... but Bank 1 Sensor 1 is the Drivers side sensor....
Check the wiring and all the connections on your Drivers Side front O2 sensor.... if thats all OK, then buy a new sensor.... Sounds like its toast!
Brian
Brian
D'oh! I don't know what the hell I was thinking... actually I probably wasn't, I had been awake for about 30 hours
At least I know front n back! Just left and right i get confused about... you should see me try to follow directions HAH.
Yeah DRIVERS Side. Definitely check the connection.... but 3 codes popping on it doesn't sound good!
Have you cleared the codes since you replaced the 02 sensors??
I don't really think that would make any difference, however, since the vehicle is still running rough.
Is it running rough at all rpm's, or just idle?
Perhaps you should reset the PCM and let it re-learn idle.
