Is This True About Methonal??????!!!!!!
OK I WAS talking to my buddy who is a well known mechanic and he was telling me that meth was really bad for your motor because if you have blow by witch everyone does pretty much if it gets anywhere neer your seals it will eat them up and you will start to leak, say oil, like a banchy every after like 4 or 5 months of use?>
just making sure the f body guys arent haveing trouble with that!?befor i go and puchase this kit cheaper then race gas~!
NO, I used my Alky injection kit on several of my Turbo cars for YEARS. If anything it helps keep the motor clean. I've taken a few motors apart and the difference in carbon deposits is amazing.
In our dragsters we run methanol and it is very common to drain meth out of the crankcase along with the oil. I doubt that if you were running meth injection you would have a problem but 100 percent methanol will pass much more than regular fuel. For one you need more meth than gasoline to make the engine run and second in a alcohol engine your compression would be much higher than gasoline. my.02
