When is the time for bigger injectors?
Old 03-19-2006, 01:09 PM
bluehawk2's Avatar
Default When is the time for bigger injectors?
I am upgrading my fuel system because I am spraying more nitrous. I just have full exhaust and the normal bolt-ons. I am wandering when are the stock injectors not enough.
Old 03-19-2006, 01:56 PM
GuitsBoy's Avatar
I have heard stock 28# injectors are good for 430 - 450 RWHP. That being said, I was running my 28's at 110% duty cycle with heads and cam at a solid 13:1 air fuel ratio. How much are you spraying? Any more than a hundred shot and youre probably pushing your luck.
Old 03-19-2006, 03:37 PM
brad8266's Avatar
spraying wet or dry? Wet does not require new injectors. A fuel pump is a good idea though for either wet or dry.
Old 03-20-2006, 09:54 PM
bluehawk2's Avatar
I am about to spray 150 wet when I get my Racetronix fuel pump installed. I think I will be safe, but I just wanted to make sure.
