Fuel Rails: Tell me about them.
Old 03-19-2006, 07:12 PM
99FormulaWs6's Avatar
Default Fuel Rails: Tell me about them.
I'm wanting to put a set of Fuel Rails on my car, I know there are a couple of companies that make them. Some say you need adaptors, etc. What is needed? Are there any that come ready to bolt on an LS1? I know there is:
LS1Speed
Aeromotive
Nasty
Any others?
Old 03-19-2006, 07:15 PM
Moderator
davered00ss's Avatar
FAST also makes fuel rails. They do need about $150 in fittings.
Old 03-19-2006, 07:30 PM
Argon Z's Avatar
http://www.thunderracing.com/catalog...vid=3&pcid=238
kinsler has rails also. Thunder racing sells them
Old 03-19-2006, 08:39 PM
227Hawk's Avatar
LS1Speed
Aeromotive
Nasty
Any others?
Factory, powder coated
Hawk
Old 03-20-2006, 04:01 AM
1QUIKWS6's Avatar
Sad but true - most of the time the fittings/SS hose runs the same price, if not more than, the rails themselves.
Nate @ Nasty Performance has a nice complete fitting/hose kit to go direct from your stock metal lines.
Old 03-20-2006, 12:21 PM
Nasty N8's Avatar
We have a complete kit fititngs and lines all you will need to bolt them on your car $319.99
nate
Old 03-20-2006, 08:21 PM
Do you have a closer picture of what your rails look like? What colors can you get on them?
Old 03-21-2006, 12:06 AM
PREDATOR95's Avatar
Has anyone dealt with the trick flow fuel rails. Will these be a direct fit.
Nasty N8's Avatar
They are polished but I can powder coat them any color you want.
Nate
Attached Thumbnails Fuel Rails: Tell me about them.-dsc00131.jpg   Fuel Rails: Tell me about them.-dsc01302.jpg
Old 03-21-2006, 12:23 AM
How much extra to powder coat? Will these affect my mileage, not that it really matters, at this point just curious.
Old 03-21-2006, 07:08 AM
mvonada's Avatar
Nate you're on it, I like a vendor who is there, thanks!
Old 03-21-2006, 07:16 AM
badass 2002 z28's Avatar
Not trying to hijack the thread...but what's the limitation on the stock rails?
Old 03-21-2006, 02:17 PM
Nasty N8's Avatar
Stock rails will feed about 600rwhp. These rails will not change milage. and most colors to coat are $15
Nate
Old 03-23-2006, 01:10 AM
Aaron's 00 TA's Avatar
Why should I buy one over the other?
Old 03-23-2006, 05:42 AM
1QUIKWS6's Avatar
They are all pretty much similar in design and I think all use the same internal fuel passage diameter. So your choice pretty much depends on price, and finish options available that are what you want...
Old 03-24-2006, 08:33 PM
sebss's Avatar
I went with the Fast Rails, I had no idea that the fittings and hoses would run approx $150 as davered00ss mentioned. If you know someone with left over #6 and #8 braided lines you can save a little since they only sell it by the 3ft sections. you'll only need 8 inches of each.
Attached Thumbnails Fuel Rails: Tell me about them.-100_1038b.jpg   Fuel Rails: Tell me about them.-100_1039b.jpg
Old 03-24-2006, 08:50 PM
CompTA's Avatar
FAST rails here...
Old 03-24-2006, 09:19 PM
dnm12's Avatar
this maybe a dumb question and sorry to hijack but can you gety a fuel pressure gauge on stock fuel rail or do the braided steel line on stock rails?
Old 03-26-2006, 08:52 AM
Michael02hawk's Avatar
I just purchased the fuel rail kit & install kit from LS1 Speed.
Everything bolted on okay enough, and I got all the braided lines/fittings assembled.
My question is tho, the end of the fuel rail, on the pass side/front.
The end of that rail kicks up right behind where the bracket is for the Throttle cable & Cruise control cable.
I was supplied a plug, which would 'barely' make the whole thing fit in that area.
But if I wanted to (and I do), attach a fuel pressure gauge, and other kind of fitting would interfere with that bracket.
Any tips?
Old 03-26-2006, 11:55 AM
1QUIKWS6's Avatar
Never heard of anyone having that problem? If you look up to CompTA's FAST fuel rails you can see that he has a FPG installed using a straight fitting and it clears the bracket. I want to use a 90 deg fitting so the FPG can be read from the side of the car.
Unless the LS1Speed rails are different? Allthough I can't see how they could be to far different as they still have to line up with the manifold mounting points and the injectors?
Quick Reply: Fuel Rails: Tell me about them.
