Accell injectors?
Accell injectors?
Hey guys, I'm looking to step up my stock fuel injectors, I have a 99 so I have 26 pounders from the factory. I'd like to go to a 30 or 32 lb injector, what do you guys think of these?
http://store.summitracing.com/defaul....asp&x=21&y=14
What about these Ford Racing ones (I'm assuming theyre the same as SVO's)
http://store.summitracing.com/defaul....asp&x=22&y=13
Thanks guys!
Thanks guys!
Dude. I wouldnt put Accel injectors in a TBI 350! I had a hotcammed LT4 and needed injectors. Go with 30lb Ford(Bosch) injectors. Their advertised lb is for a ford fuel system(lower fuel pressure) and 30lb'ers will flow more like 33lbs without exceeding 85%duty cycle. The price increases significantly after the 30lbs injectors, also. Worked great! Do you really need injectors, yet?
