FI 800 hp fuel pump
Old 03-28-2006, 08:35 AM
7 Second Club
ty_ty13's Avatar
Default FI 800 hp fuel pump
what pump are you guys using to get about 800 hp for FI?
if got the nasty fuel cell also
Old 03-28-2006, 01:08 PM
andereck's Avatar
At what pressure? The stock 60 or so psi?
Flywheel horsepower?
Old 03-28-2006, 01:28 PM
Wicked_Hugger99's Avatar
im running twin 420s at 851rwhp
Old 03-28-2006, 01:59 PM
7 Second Club
ty_ty13's Avatar
60psi and crank hp
Old 03-28-2006, 02:03 PM
Nasty N8's Avatar
Weldon 600A
Nate
Old 03-28-2006, 02:23 PM
7 Second Club
ty_ty13's Avatar
Originally Posted by Nasty N8
Weldon 600A
Nate
this one?
http://www.weldonracing.com/600aflowthru.html
60gph?
Old 03-28-2006, 03:29 PM
Blown408's Avatar
Originally Posted by ty_ty13
Mine ran out at 700rwhp. I had to dump alot of fuel through my 75lb injectors to make it to 750rwhp.
Old 03-28-2006, 04:30 PM
Nasty N8's Avatar
He asked for 800 crank HP The 600A will do that no problem. I thought your car made 750 to the wheels?
Nate
Old 03-28-2006, 04:52 PM
7 Second Club
ty_ty13's Avatar
800 at the crank with FI
Old 03-28-2006, 05:07 PM
7 Second Club
ty_ty13's Avatar
i searched and found alot of guys are using 2 600a weldon pumps...
how much can one of those feed a FI car and how much can 2 of them feed on a FI car?
and if i just put one now... could i just add anoher later if need be?
Old 03-28-2006, 05:09 PM
andereck's Avatar
I suggest the Aeromotive Eliminator 11104 for 800 hp. The pump makes 90 gph or 525# hr @ 12v and 60 psi. You should also consider a speed controller for street driving to keep the heat introduced by the plumbing to a minimum. The pump would be good for 900+ hp. It plumbs with a -12 inlet and -10 outlet. There are several low 9 second cars running this pump. It has the same motor as the A1000 so it will be happy in a driver. The pump will put out approx 20% more volume @ 14.5 volts.
I don't care what anybody says, the 600A is not in the same department and Weldon themselves do not rate it for that power level. It might or might not deliver, it sure isn't supposed to.
Old 03-28-2006, 06:42 PM
7 Second Club
ty_ty13's Avatar
i know nasty N8 knows things from experience...
Old 03-28-2006, 07:59 PM
Blown408's Avatar
Nate
You are right, my car did make 750 at the wheels just like I replied above. I missed the crank HP though, one Weldon 600A should do it.
Old 03-29-2006, 11:39 AM
Nasty N8's Avatar
Sorry just saw the 700hp part almost thought we were heading backwards I want feed back from you guys as much as possible too I want to know exactly what my stuff is cappable of. I am working on a few more systems some cheaper, some more and some to handle more power. Street and race.
Nate
