New Magna Fuel street pumps up to 2000hp
These are not there race pumps these are designed for street use and do it very well. MagnaFuel strongly does NOT rec. a voltage controller they specificly told me they are not good for there motors. As long as these pumps are coupled with the correct size fuel line and regulator you will not have issues on the street.
Nate
Nate
It doesn't drop the voltage, that's the key. Its pwm controlled so it hits the pump with full system voltage. Now if you were to use a dmm on it you would see that it averages about 10v to the pump with a 14.3 v supply. This is an averaged dmm reading though. The pump will last longer as it doesn't work as hard and the amp draw goes down. Regulated pump volume drops about 40% when its active on the low side. Thats significant.
The box will also run 6 seconds at full volume when you start the car and when you shut it off to keep the system primed. You can have it go 100% via rpm, or a grounded external switch, relay, ecu etc. Pretty cool. It will sink a bit over 30 amps so it can control pretty serious pumps.
Originally Posted by kp
You sure its PWM? I had one for a while (came on a car I bought) and while I never put a scope on it after using it with an A1000 for a while it melted both spade lugs of the controller so I assumed it was drawing more current. Not to mention I burned up two A1000's when using it. After I got rid of the controller the pump lasted a long time..
Originally Posted by Boodyrider
Do you have a flow/pressure/draw chart for these at various voltages?
http://www.magnafuel.com/catalog.pdf
Yes, I'm sure its PWM. There was a run of them with a component substitution that resulted in high amp draw and the potting would melt back from the terminal. The resulting heat was evident on the backside of the driver. You could see where the potting had softened around the component. This was cleared up some time ago. I'm surprised your A1000's burned up. They have pretty good sized brushes and they fit the commutator well when new.
I just assumed it was DC-DC converter and was overheating everything from the increased current draw at the lower voltage..
Coal Mining Director
Fuel heat has nothing to do with line size when FP is regulated to 58psi. If those pumps are pushing (a guess since they don't publish flow data ) +600lbs/hr through a 58psi regulator, the pump may never fail (properly designed) but the gas is going to heat up on long trips....better design for it.
As far as flow data procharger doesnt publish any either and I have one on my car and its doing OK. I'm sure the data is there but they just dont want to share for whatever reason, I dont like it but you dont have to know how to build a watch to tell time properly if you know what I mean
You an always put a small A2A cooler on the return line, have had one on my car for over a year, dont know if it really helps or not but its there lol.
Kev what brand ya got and is it for a -10an line???
Im looking for one just because.....
Thats so true LOL
Kyle
#33
Originally Posted by Nasty N8
Kyle you surely don't have -10 on your return line?
Good one there Nate..... thanks on that one nah i have -8an as my return......-10 is my feed.....
Ya have any Nate????
Pm me a Price for one shipped to 23452 and ill give ya a ring.....
Kyle
#34
Thats so true LOL
Kyle
Thats so true LOL
Kyle
*edit, its a flex-a-lite, just found the receipt
