adj fuel pressure regulator w/ boost ????
Old 10-29-2006, 03:04 AM
ssdriver27's Avatar
Default adj fuel pressure regulator w/ boost ????
I bought this boost referenced adjustable fuel pressure regulator, I should have asked ahead of time but will this work for me? the reason I ask is, I read a little closer and in the description it says adjustable from 36 - 45 PSI If it will not work what should I go with? if it will work any advice or help with installing and adjusting would be appreciated as there were no directions included. I also bought a 255 lph walbro fuel pump to go with it if that makes a difference. thanks ~Guy
http://cgi.ebay.com/ebaymotors/MSD-...1QQcmdZViewItem
Old 10-30-2006, 10:50 AM
sonicbaloo's Avatar
Most stock GM vehicles require 60 psi. You could run less but the tuning will be scaled way off. I would recommend using a Aeromotive FP regulator.
Chad
