Quick release fuel tank fitting
Old 12-21-2006, 02:55 PM
speedracer5532's Avatar
Default Quick release fuel tank fitting
I am looking for a quick release fitting that will hook to the factory line at the tank and let me run a -8 AN hose forward. What are my options?
Old 12-21-2006, 03:52 PM
Nasty N8's Avatar
Russell makes a 3/8" quick connect to -6 male but there is no -8 fitting you need to use an adapter.
Nate
Old 12-22-2006, 09:12 AM
jstacy's Avatar
Aeromotive has one. 15118 AN-08 to 3/8 Female Quick Connect Adapter
Old 12-22-2006, 06:59 PM
True but the Aeromotive one isn't available until the end of January.
Old 12-26-2006, 08:05 AM
jstacy's Avatar
Yes it is. Call Summit and have them special order it. They will tell you 4 weeks but I know for a fact that they have 1 15118 and 2 of the 15117.
Old 12-26-2006, 08:29 AM
Old Geezer's Avatar
?? why use the -8 hose, if the tube feeding it is a -6????
Old 02-13-2007, 01:31 PM
ss1
ss1's Avatar
Sorry to bump this up after a few weeks, but I was wondering the same thing. What is the point of running a -8an line if the plastic tube feeding it is 3/8"?
One would think an -8an bulkhead fitting would be the way to go, but it isn't really an option with the plastic sending unit assembly.
Old 02-13-2007, 01:52 PM
Nasty N8's Avatar
The fitting on the sender is fine with the pressures but it is good to step it up to larger line for the added volume.
Nate
