42lb SVO VS. 42lb Lucas....any difference
Old 12-31-2006, 09:49 AM
99WS7's Avatar
Default 42lb SVO VS. 42lb Lucas....any difference
Just seeing if one is better to use then the other.
Old 12-31-2006, 11:29 PM
Gary Z's Avatar
The Lucas disc-type injectors reportedly have a faster response time and therefore could perform better at idle and low engine load (narrow pulse width) than the slower pintle-type injectors. There should be no difference at WOT.
Old 01-01-2007, 08:28 PM
Robert56's Avatar
The SVO Ford injectors are rated at 45psi and when running them at our pressure of 58psi they become 47/48 pounders. I run these on my car.
Robert
Old 01-02-2007, 12:01 AM
99WS7's Avatar
huh, good info from both of you. Thanks.
Old 01-04-2007, 08:49 PM
ldickson's Avatar
The Lucas also become 48lb at 58psi
Old 01-04-2007, 11:42 PM
The1N_only's Avatar
Lucas > SVO's
Old 01-05-2007, 07:52 AM
erikthegoalie's Avatar
I have the 42# green tops from SVO....we shall see what happens...
Old 01-07-2007, 11:46 PM
35th SS's Avatar
lucas here and no problem.easy to tune.
