2002 28lb injectors vs Ford motorsport 24lb injectors ???
Here we have two injectors rated around the same, so, is there any advantage of one to the other? From what I gather, they are both bosch and both have 4 holes. The fords look like they have a fatter body, but, that just may be the old school look.
I have a Jeep stroker that needs 24lb injectors and a tired set of injectors on the camaro. Since I have a new set of stock 02 injectors ready to go, I was wondering what the diferences are in them before I stuff them in?
Thanks blur, well, and I do not know if this is correct, but, using a fuel flow calculator, a ford 24 flowing at 40psi, then upped to 58psi would give 28.89 flow respectivley. Now, throw in a 3lb varience, which one could live with, and "theoreticly" they are very close to the same. I just wonder what internal differences make either one better over the other. I know, not something to really worry about, but, since I am going to HAVE a choice, why not get the better of the lot? Just something I am checking into before I buy in case there is something I dont know.
