fuel pressure
Old 02-05-2007, 08:16 PM
Restricted User
WS6nJAX's Avatar
Default fuel pressure
how long should i maintain fuel pressure (via my rail gauge) after i shut the car off?
Old 02-06-2007, 02:09 PM
WhiplashDVD's Avatar
mine starts to bleed off after a few minutes
Old 02-06-2007, 04:14 PM
Restricted User
WS6nJAX's Avatar
thanks dude. didnt know if that was normal or not.
Old 02-06-2007, 09:29 PM
I assume so, mine builds up to around 70 when running and then when not after about 5 minutes it floats around 20 to 30 psi
Old 02-06-2007, 10:58 PM
Kleeborp the Moderator™
MeentSS02's Avatar
70 psi? Damn...what pump/regulator are you running?
Old 02-07-2007, 07:45 AM
Racetronix pump, hotwire kit, and stock reg. Ill have to take a pic when i can get it running again. Problems with too much fuel since pump swap.
Old 02-07-2007, 07:52 AM
now before i look bad this was at idle when the car was running. It was more of a max pressure reading.
Old 02-07-2007, 07:58 AM
RedWS6 00's Avatar
70psi on stock regulator, surely something is wrong, the regulator ment to regulate to a set pressure.
As for fuel pressure drop off, mine sits just under 60psi straight after shut off, after about 4 mins, its down to 30psi, and about about 10mins all the pressure has gone.
Old 02-07-2007, 09:03 AM
Restricted User
WS6nJAX's Avatar
thats exactly what mine does. having what appears to be an un-metered air situation, have tried EVERYTHING and just reaching for some sort of hidden problem right now. thanks.
Old 02-07-2007, 09:37 AM
RedWS6 00's Avatar
Dont think of it as a problem, its normal for the pressure to drop off when the pump isn't running. The fuel is probably going back through the regulator or something due to no pressure on the other side of the regulator as the pump isn't running after shut off.
Or am I missing sometihng here, I've probably missed the question. What do you mean Unmetered Air?
Old 02-07-2007, 10:33 AM
Restricted User
WS6nJAX's Avatar
long story....
did a complete top-end rebuild. heads, cam, everything. had a weiand intake on the motor and was having all the symptoms of un-metered air while trying to get a tune. the iac reading keeps bouncing up and down, do to what appears to be air entering the intake/system somehow. decided to blame it on the weiand and sealing issues. purchased an ls2/ptm combo. did the install. and i'm still having the same problem(s). when throttling up while in park, the idle hangs for several sec's. also we cant get it to idle below 1000 rpms no matter whar we do. have checked everything. i found a cracked vacuum line and repaired it. but still the problems continue. i really was just fishing when asking about the drop in engine off fuel pressure. i am at a total loss at to what else to try here.
