How Much power
I recently talked to Brett Clow at Aeromotive about this exact
same scenario because I am also running an A1000.
He said that it depends on if you are boost referenced or not.
The A1000 flows well but does not like high rail pressures.
If you are not boost referenced, with 96lb injectors you can
squeeze out 1000 flywheel HP.
But if you are boost referenced at 15psi of boost, he said to be
careful with anything over 750 flywheel HP.
Give him a call if you are in doubt about your setup as he
really knows what he is talking about.
